Old question how do you post pictures here?
Clifton Viper
Clifton, VA.
From FAQ:
In order to add an image to your message or your signature, you must have the image already available on a web server. This can be an image on your own personal web page, for example. To place an image within a message, simply use the following Markup Tag:
http://www.url_to_image.com/image_name.gif/
For example, if you have an image called cateye.gif and its available from your own website at http://www.mywebsite.com/pics, then you would use the following image markup:
http://www.mywebsite.com/pics/cateye.gif
Note: To keep the forums loading quickly for everyone, it is recommended that you do not exceed 35k for your image size.
You basically need to save the image on a web page and refer to the URL in the text of your post. You can often ask more technologically inclined users (not me!! :crazy: ) to post them on your behalf.
If you do it yourself, go to the FAQ section as I had to delete some of the "UBB" code to copy and paste.
Good luck.
V10 MOJO
Youngstown, Ohio
ok good advice, im lost, but good advice. but how do you post pics actually displayed in the message, not a link to them?
Quantico, VA
Here are some quick tips on how to use the Viper Club of America Image
Gallery. It is important to remember that you MUST be logged in to
the Gallery in order to upload images. Currently the username
database for the Gallery is not shared with that of the Discussion
Forums, so it might be necessary to register separately for the
Gallery. If this is the case, simply register for the Gallery with
the same info you use on the Forums (at some point we will be merging
the two databases and this will make it easier for all of us). Go
here:
http://www.viperclub.org/menus/index_media.htm
And either LOGIN, or REGISTER. Once you have done this you will see
up near the top right the option to UPLOAD PHOTOS. Click on that link
and follow the steps to upload your images into your personal folder,
or pick another area you want them displayed by choosing a CATEGORY.
Please note that the limit for each image is currently 200K.
Once the image is uploaded, view the image to make sure it was
uploaded OK. If it was relatively large you MIGHT see different
variations on the "Filesize" line, just above "Keywords" and
"Descriptions", listed UNDER the image. Ideally, you want to select
an image around 60K in size and 640x480 in dimension (for display on
the Forums).
For me, the easiest way to ensure I have the right image, I RIGHT
CLICK on the image and select "Properties". A box appears and it
tells you the file size as well as the dimensions. In that same box
it shows the "Address" (or URL). Highlight and copy that URL
by RIGHT clicking on the highlighted URL and selecting "Copy".
Now, all you have to do to post that image on the Forums is, while
composing your message, include the URL between the image tags, like
so:
<font class="small">Code:</font><hr /><pre>
[image]http://vca2.viperclub.org/gallery/data/500/210DSC00167-med.jpg[/image]
</pre><hr />
Now, preview your post to make sure the image appears. If you run
into ANY problems please let me know. I put this little "How To" note
together based on my experiences. If you have a problem, or find
there are steps missing or poorly explained, please let me know so I
can "fine tune" this message.....Thank you very much!
BarryLB
