GTS Bruce
Ok I finaly got my gt2 stock splitter and canards painted car color. I was told the original splitter brackets were N/A. So does anyone have some lying around? Jon B does not. If not pics of yours please! Yeah I'm sure something can be fabbed or worked out. Just looking for the easy way if its out there.Driving season is still a couple of months away here. GTS Bruce
Original splitter price. Check with Jon B. He has them. Less than snake Oyl. Just haave to figure out how you want to mount it. The original is slotted so it can be extended or retracted. Still looking for some brackets,pics,specs. Herb say it generates a little downforce(probably extended). Just trying to eliminate gen-2 nose lift. GTS Bruce
"Parts Not avilable" wont catch the right fish!
Bruce, this picture shows how the splitter is mounted. There are two of the large aluminum discs at each end of the splitter and three of the stamped aluminum "channel" brackets centered and spaced on the vehicle. The two outer channel brackets are drilled in pairs. Inside the facia are aluminum washers and nuts backing up both the discs and the channel brackets.
I have full dimensions and addtional pictures I can e-mail or fax to you if you give me your address. I don't have the equipment to manufacture the brackets of alumininum but could do them in steel.
Fish Much Jon?
Bruce ended up catching a BIG FISH
Sorry had to bust on ya...
BTW Thanks for sponsoring Mopars at the Strip!
http://forums.viperclub.org/nevada/622912-western-zone-rendezvous-march-20-22-a.html
