Performance Computers and Programs 1992-2006 models
Daniel Cragin/DC Performance Inc
Los Angeles, Ca
DC Performance offers custom computer programming for all year models.
-Replacement computers available
-Proven SRT calibrations
-Supercharger programs
-Custom programs from your dyno sheets.
-Calibrations for larger injectors
-Overnight service
For pricing and info regarding your specific vehicle please call.
Dan Cragin
DC Performance Inc.
310-841-6996
www.dcperformanceinc.com
96GTS
Dyess AFB, TX
I've got a 96 GTS, and I like the rough idle. I already have the skip shift disabled, and I've never seen the temp gauge over 190 degrees. What benefits could I expect from this?
SSSSE YA
Simi Valley, CA, USA
Dan Revised mine and My Viper has an noticeable increase in mid range HP 30 more Hp before and after dyno readings. The engine is a lot more responsive. Dan optimized fuel and timing curves for My type of driving needs.
He is one of the best, Dan is the only one who works on My Viper!!
:usa: :D :2tu: :usa:
96GTS
Dyess AFB, TX
I've heard a lot of good things about DC, but also heard the results for the 96 GTS were only about a 5-10 horse gain for a reflash. If the results were really 30 horse, it would be worth it. Do you have a dyno sheet you could post here?
SSSSE YA
Sorry I took so long, working long hours.
96GTS
Dyess AFB, TX
Was this from just a reflash, no other mods installed with it? Does it still have the lumpy, "big cam" idle? If you had it to do over, would you do the gears, flywheel and rockers again?
SSSSE YA
Just the reflash, YES YES YES My viper is fast I can Light the 355'S up in 3 rd gear now with no problem, next is Striker heads maybe by the end of this year. I have talked to Dan a little about them, but my good friend Armen has done some research on them, good for 100 Hp.
Good luck
