Porting the Gen 1 throttle bodies.
Shanedog
Kansas City
I was wondering if you all reccomend porting the stock TB's on the Gen 1 cars. I have seen several places selling aftermarket ones for the Gen 1, and they say not to be used on the Gen 2's...why is that?
There is a guy here local that will port mine for about $150, does that sound fair?
How much power might I expect?
How much larger can I go?
Are there any possible problems I could get from doing this?
Thanks in advance.
joe117
Maryland, USA
I've never done it but I can tell you what I've heard most often.
I think most of the guys will say that it might give you a small top end power boost.
The downside is that it will hurt your lower end power.
The general advice will probably be not to do it.
FE 065
MI
A vaccum gauge added behind the left TB on my Gen 2 shows virtually no vacuum at WOT. Meaning the engine's getting all it wants through the stock TBs unless you're running a big cam or something to increase the vacuum..
I cleaned up the inlets a bit on mine for a little more CFM w/o disturbing the overall throttle response
Shanedog
Kansas City
So all and all it is probably not the best thing to do? I have done the intake and exhaust and was thinking this might be the next step, but now I have my doubts.
Thanks for your replies.
99 R/T 10
Enterprise, AL USA
If you do it in conjuction with 1.7 roller rocker, you may see a benifiy. I have a set of Gen I TB's that I was going to use on my 96 until I sold it. Stock is 58mm these are 62mm. I also have a set of Mopar RR(T&D's) in the classifieds if you want both. If you don't like the bigger TBs, you can always go back to the stockers.
zeeshan_k24
