Proper way for closing hood?
Saint_Spinner
Los Angeles
Just thought I'd get prepared before I get my Viper. I was wondering whether you guys can give me some pointers on the proper way of closing the hoods? I know this is one of the biggest problems most noob owners encounter.
There's a large debate over on the corvette forums regarding closing the hood via "dropping" or "pushing down" and which method causes cracks in the fiberglass. Any tips most welcomed! thank you!
94RT10Ohio
Northwood, Ohio
Slowly lower until the hood "rests" against the windshild area.
This is the important part. Go around to the front and DO NOT PUSH near the edge of the front of the hood. You should use the palm of your hands back near where the hinge attaches to the hood. Pushing near the edge, especially where the hood curves to form the point to for the headlight hole can result in damage.
There should be no slamming need, a simple push should close it.
V10SpeedLuvr
I'm assuming you already know how to open the hoods? I've seen some great looks on people's faces (some mechanics included) when they go to pop the hood and cant find the hood latch handle inside the car :)
Saint_Spinner
Los Angeles
Actually, no, I don't know how to do that either...I'm guessing its easier than closing? I've seen someone do it, but I can't remember everything. I hope its in the owner's manual :D
V10SpeedLuvr
Reach in the upper RH section of the front bumper and you'll feel the latch on the RH side of the car. Simply push it down and the hood will pop up. Then, go up near the windshield and grab the hood on the side and in the center and lift up. Easy as 1-2-3 :2tu:
red98RT10
Greenville, MS
V10....you missed a step for a Gen II at least. First use the latch in the front grill and the hood pops up an inch or so. Then there is another latch directly under the part that just popped up(closer to the driver's side). Push this towards the center and lift again about 8 more inches. THEN, go to the windshield side and lift (using two people or with your hands as close to the middle of the windsheild as you can reach. :2tu:
Saint_Spinner
Los Angeles
wow. Thanks guys! Will all this be illustrated in the owner's manual as well? Or will it just say "Pop latch, lift hood"?hehehehe
ViperJoe
Virginia
First the Viper hood does not open or close like the Corvette's. Dropping it like the Vette's will not close it. Opening and closing the Viper's hood is a multi step process.
Once you at the final "opening" point, 2 people would be the ideal to "lift" the hood up, if not, just be sure to lift it at the centermost point at the rear of the hood.
Closing the hood:
Press both hands firmly down atop where the hinges mate to the hood - this is just inboard of the vents - about halfway down the vents (think of the middle vent as the spot, then move inboard on each side about 6 to 8 inches)
Poke your head under the hood and line up where the hinges are to get a good visual. You'll get used to exactly where they are over time.
It does take more force than what I was using originally - I think that my initial force was in direct correlation to the cost of the hood. I found that using a little more force in the right spot did the trick
My logic for this is simple - all stress is being applied to the actual support system for the hood and not in between them, reducing the potential for stress cracking, etc.
Also, I find that first gently closing the hood down completely to where the latch rests against the loop, then opening it up to the intermediate open step before finally shutting it firmly helps. Not sure why but it just does.
After closing the hood down.... press down at both rear corners to make sure they are all the way down before you go to the front to push it down.
Close it with your hands just above the NACA duct.
Give it a pretty good, even push.
DrumrBoy
GA
If it closes at all hard you can throw the top latch (by the hood, not the grill) BEFORE pushing down on the spots by the hinges. One less thing to work against....it just makes it easier to push down.
KenH
Portland, OR, USA
They give you a video to show you how to open and close the hood among other things, but it showed the guy way too far forward on the hood when he was closing it. Info you are getting here is better.
Midwest Muscle
Springfield, MO
Does this mean I'm the only one that covers my hands in microfiber towels while pushing down on the front to close it? Yeah ... probably so!
Mike M
G
grcforce327
Guest
Mike M
Microfiber here too!! :headbang:
G
grcforce327
Guest
V10....you missed a step for a Gen II at least. First use the latch in the front grill and the hood pops up an inch or so. Then there is another latch directly under the part that just popped up(closer to the driver's side). Push this towards the center and lift again about 8 more inches. THEN, go to the windshield side and lift (using two people or with your hands as close to the middle of the windsheild as you can reach. <img src="/forums/images/graemlins/2thumbs.gif" alt="" />
Move to front of car and bend over first!!! :D :2tu:
BarryLB
