I just replaced all of mine over the winter. I used the 3m and cut it myself. It was very simple.
3M Paint Protection Film, Strip, 84904, 4 in x 84 in
You can buy pre cut kits from sires like Paint Protection Film - XPEL Technologies Corp. or Paint Protection and 3M Clear Bra for your vehicle. Also known as Rock Guard..
Yes, it gets stretched over the compound curves. Complicated pieces are best left for the professionals.
If you want to install yourself, I can get you the kit if you like. PM me
Small curves were easy, but like Agent says leave complicated curves to the pros. I didn't do any hard curves on my RT. I didn't use a heat gun just a lot of juice and elbow grease.
Let it cure if you can, but if the paint was preped good, you shouldnt have a problem. Today I did a rt/10 that had its nose repainted and it was not a very good job, it did peel the clearcoat at a couple spots. After reapply the clear bra, you couldnt even tell, its all on the job. Who ever did this job, painted the nose on the car, didnt remove the emblem, it was a s*%&y job. You should not have a problem but if you can wait 30 days, its better but I have seen it put on within a day. If you do remove it, use a heat gun and it will peel right off.
when i had my fascia painted the guy wanted to wait 60 days to be sure it was FULLY cured.
