rear Caliper tool
pdmracing
Atlanta Ga
Per shop manual, do you really need to screw the piston back in with the tool?
If not how are you doing it?
The Year Matters: 92-00 = needle-nose-plier tips firmly planted in the piston dimples, push and twist. Be sure not to let one tip slip out and 'walk" across the piston face, scratching it. (like I did the 1st time) Tom replaced those tiny pistons for me!
Tom Sessions
Hampstead,NC.
Like Jon Says year matters. If you have a 01-02 ABS car you do need a special tool to turn and push the piston back in.
Chuck 98 RT/10
tampa, fl USA
My pistons on both Vipers were a real pain the first time. The tool would have made it much easier than all the other options. I've since gotten to tool.
No difference unless you score the perimeter edge while your at it....its just easy to let it slip..
Tom F&L GoR
Wappingers Falls
...and poke the dust boot. However, a 40mm conversion would clean up any types of oop-sie you could ever do. Even with vise grips...
JpKL
