Rear speaker removal
ViperBite
Orchard Park NY
On a 02 GTS, how do you get to the rear speaker to remove it? I started to take some of the trim pieces off and decided to ask before I tore out the whole trunk area on to find a better solution. The plastic pins on the speaker cover will not come out and the board holding the covers on are very flimsy.
Just bought some Polks to replace the fronts and thought I would do the rear as well.
TIA.
Got_Vnum
Northridge, CA
You need to carefully slide the carpet material out from underneath the vinyl on the back and sides. Take your time. I found it easier to start at the sides and work my way to the rear. The grilles will come off with the carpet. Speaker removal is easy after that, just screws.
ImmaThnake
