Rotating tires
Steve M
Dayton, OH
Will I have a problem with the Tire Pressure Monitor system when the tires are rotated ? Thanks .
It shouldn't...I don't think the systems in these cars actually know where the sensors are, it just needs to see that they are there and reporting.
Roysviper
Milton,FL
Rotate the tires on your Viper?
UOTE=redrichard;3171740]Will I have a problem with the Tire Pressure Monitor system when the tires are rotated ? Thanks .[/QUOTE]
Roysviper
Milton,FL
Everyone I know only rolls one way, ha.......just kiddin.........surly he don't mean rotating from front to rear? Unless it's like the story I read the other day about a Viper that the guy put the same size tires on the front and rear.....
PS2's are not directional.
They have an inside/outside tread pattern. Roll either way.
R
redrichard
Long Island
Finally got the job done, rotated tires cleaned inside of rims those rear tires are heavier than I expected. Grease the upper ball joints and cleaned inside wheel wells. On inspecting tires I found a screw in one of the fronts, pulled it out with a needle nose and it did not leak !!!
