BullRider
My '01 RT/10 was getting some wheel hop when I got the tires spinning, so I decided that it might be time to consider swapping out the stock mounts for polyurethane. A quick order from Jon B later and I threw the car up on jackstands and got to work.
I started with the tranny, and this is what I found:
The mount was completely shredded and totally separated. I dropped the tranny (and installed a B&M Ripper short shifter at the same time), and threw the new mount in. Super easy install and it took about 20 minutes.
I then moved onto the engine mounts. They looked alright from a quick visual inspection. But when I got them freed, I found this:
BOTH engine mounts were completely split. This means that nothing was holding my powertrain down at all except maybe my manifolds.
I've got the old mounts out, and I hope to finish up tonight getting the new mounts in. I have no doubt that it will feel like a new car with the mounts and shifter in place now.
Anyhow. If your miles are creeping up and you haven't already checked them, inspect your mounts and if they look questionable, swap them out. Its a pretty easy process (probably two hours all in if you don't have a lift).
BullRider
BullRider
