Sway bar bushings
corvette Lin
Florida
Need front and rear sway bar bushings in my 2008 viper convertible. Any tips where to get them from so I can have my husband install them? Thanks in advance
If you google energy suspension polyurethane bushings for your year Viper, you will come up with a bunch of purchase options.
In that case, do a search for sway bar endlinks made by Mevotech, Delphi, or Moog as a start. I'm not sure which companies bought which, or who is making who these days. There are many, and opinions and experiences will vary. I would figure if your driving is not overly demanding, most will probably fit your needs just fine. If you intend to autocross or track the car regularly, then I'd dive a little deeper into oem level vs upgraded options.
You might try RockAuto. I think I got some for my 04 there on closeout a while back. They tend to run on the moderately expensive side ($50+ a set), but I think I snagged them for more like $20-30. Can't remember which ones I ended up with, but generally speaking they seem to work fine. I think it's usually more of a longevity thing than a function problem when it comes to the different brands.
valrom
