I'm finally getting to installing my T&D 1.7 rockers. I have some questions for those of you that have installed the T&D's on a GenII.
Background:
- Stock engine except for exhaust and headers. Stock heads, valves, etc. I'm not changing valves, no head work, etc. Stock engine (for now).
Checking for Proper Geometry:
- The T&D rocker kit includes a shaft-height gage used to determine the proper geometry. In order to get an accurate measurement, the gauge must come in contact with the top of the valve stem. Do I have to remove the valve spring retainer, retaining locks and valve springs or is there another accurate method of checking the geometry?
- When removing the valve springs and checking the geometry I obviously don't want to drop a valve. I understand the valve needs to be fully seated when checking the geometry but is keeping the piston at TDC enough to prevent a valve from dropping?
- If the rocker stand needs to be raised I have plenty of shims that came with the kit. But if the stands need to be lowered, T&D recommends removing a 'corresponding' amount of material from the stud bosses on the cylinder head. I read a recent post by Greg Good that indicates its ok if the T&D's sit a little higher as long as they don't run off the edge of the valve tip. I'm curious as to how many Viper owners with a stock engine had to lower their T&D stands due to incorrect geometry and what was done to correct the geometry.
Measuring Pushrod Length:
Once the stands have been installed with the proper geometry I will measuring for new pushrods. Thanks to Dan Lessier I've decided to go with Trend pushrods and I have a pushrod length checker on the way. I'm following T&D's instructions for checking length which seem straightforward. Question: When adjusting the pushrod checker should it be snug against the adjuster? T&D is not very clear on this.
Oil Pan Baffle:
I don't see the T&D's fitting under the valve covers without hitting the baffles. Is it OK to simply remove the baffles? What have you done for this?
Is it necessary to soak the rockers in 30w oil before installing? I think read that for Harland Sharps.
That's it for now. I'm sure I'll have a few questions on setting valve lash but we'll cross that bride later.
Thanks.
- Tony
Background:
Oil Pan Baffle:
Thanks.
- Tony
