Thanks Roe Racing....Again
Woody
Kentucky
Thanks to Sean & Company at Roe Racing for another excellent experience. :D I took my GTS down last week during vacation and had the Water/**** system installed, along with a 6.5lb pulley. I gained over 31RWHP & 30RWTQ. In addition, I moved my torque curve quite a bit lower in the RPM band. Previously I had hit 555RWTQ at around 3600RPM. Now I am hitting 599RWTQ at about 2850RPM. The car runs great and the SOP meter is off the scale. :headbang:
Again, hats off to everyone at Roe for their professionalism & courtesy.
plumcrazy
ALL OVER
they do rock.
im doing the same thing on my vacation, having sean tune my vec2 and nitrous while im there.
Dave T (BADVENM)
Goodland, KS
*****, are you running the 6.5# with stock pistons? I'm guessing the **** injection will compensate the 1.5# increase in boost and keep everything under control piston wise?
W
Woody
Kentucky
Yes. I spoke with Sean about it and he said that he felt it would be a safe move as long as I was doing the water/****.
Sean Roe
Jacksonville, FL
Hi *****,
You're welcome.
You should put a picture of your car as your avatar.
It's sharp.
Regards,
Sean
W
Woody
Kentucky
Thanks Sean. I am getting my 'new' powdercoated calipers from R&J put on tomorrow and after a quick cleanup, I am going to get some photos taken & posted.
zeeshan_k24
