luc
What is the name of the tool to remove a plug with a square hole in it instead of torx,etc?
Luc 00GTS
Luc 00GTS
Ladies... Pay attention!
They are pipe plug sockets. And if yours doesn't fit you have not bought the correct size yet, because they have them all.
Here's a link to SK's web site.
I buy them from toolsource.com.
SK Hand Tools: Professional Tools Since 1921
But did you get the top bleeder screw out or just remove the block drain plugs? Could you post a picture of the S&K socket you purchased that worked on the bleeder/burp screw? I found that no normal sized socket would fit (meaning typical diameter of the socket base). I purchased the correct size..but that wasnt my issue. You need something quite small in diameter to fit in the hole and not hit the intake manifold. After looking at the S&K link again, it does appear that they are smaller than the Snap-On sockets.
Either way, nobody sells a tool that can be used without a little grinding. Cheaper to buy a 3 dollar 1/4" extension and grind that down to fit.![]()
