Racer Robbie
I am about ready to install a new set of OEM size Michelin NON RUN FLATS on my 2003 SRT-10 Viper. They are going on a new set of Copperhead ( Sidewinder ) wheels from Parts Rack. I have decided to run my old pressure sensors, though I hear it is not necessary to do so. These Sidewinder wheels are 34 lbs lighter than the stock OEM wheel and the tires are 10 lbs lighter than the OEM Run Flats. This is a total weight savings of 44 lbs of unsprung weight. Using a stock suspension, with this 44 lbs of saved weight, what would you set the pressures at front and rear cold? Also what pressure are you looking for once the tires have come up to temperature?
