Torque of ACR rear tires?
Jake654321
Just had a flat tire on my 2002 right rear titre. When I putr back on, what torque should the nuts be. Any particular paatern best. Cross bolt, isequenjcial? Does it matter? Please don't move to off topic.
The guys here will know.
Thanks, Jake
J
Jake654321
Just read this. I think I can spell, just, apparently, can't type.
Sorry
Service manual says to "Tighten the wheel mounting stud nuts in proper sequence until all the nuts are torqued to half specification. Then repeat the tightening sequence to the full specified torque of 122 N.m (90 ft. lbs.)."
The sequence is an alterating pattern AFTER you start with the nut on TOP, then go to the lug on the bottom, then skip to the right upper side nut, then left lower nut, then right lower nut, then left upper nut. I personally use this method as well...and retorque at 5 miles then again between 25-40 miles...all to 90 ft. lbs.
J
Jake654321
Thanks everyone. We'll repair the nail hole and torque as you suggest. Thanks Again
