track tires
PhilC
Jackson, NJ, USA
Found some 18" rims now I need some Hoosiers to go on them. I wanted to check with some of you track gurus as to size. Will this combo work 315 30zr 18 front and 335 30 zr 18 rear . Would a different comb be better for any reason.
Thanks in advance
Phil
Omaha NE.
You will love the extra grip the 315's will give to the front of the Viper! Perfect as far as I'm concerned :2tu: . I have seen people use the 335 up front also though! :headbang:
Mark
P
PhilC
Jackson, NJ, USA
Thanks, I appreciate the response. I was just a little concerned that the 315 front and 335 rear was not a big enough width differential from front to back.
Thanks again
Phil
Thanks in advance Phil
Ive been running 315-335 since 1993 !!!!!!
Catwood
I really like the 315/335. The 335/335 felt good but it felt like the rear would break loose first.
Carl
DrumrBoy
GA
I'd definitely go with some Monster Truck tires...., you won't necessarily corner better but folks'll definitely stay out cho way!:drive:
See you in B'ham dude.
:headbang:
zeeshan_k24
