Viper Scot
I have a 1996 RT/10 with a Paxton set-up (with some uprated parts over the kit spec, 50lbs injectors being most relevant). I'm finally in the process of getting the car mapped right now. I'm using a Split Second fuel and timing controller (FTC1) to modify the basic tune on the ECU across map cells and I'm wondering what base map I should start with on my factory ECU (i.e., the base factory one or something).
However, the FTC-1 unit can only reduce fuelling or retard timing. So I was wondering if I want to start with an ECU tune that is factory apart from having quite advanced timing and then start the tuning process with a lot of retard on timing on the FTC1 (to more than counteract the advance on the ECU tune) and pull back from there? This is the only way that I can see how to effectively have the ability to advance timing using the FTC1.
Alternatively, is the standard ECU tune effectively advanced enough (relative to what is require for a s/c car); i.e., given that I'll need to retard for on boost positions on the map? What about off boostmap cells though?
I thought that the standard ECU tune would allow more subsequent flexibility during tuning (the effective ability to advance timing) than one that was tailored to a Paxton set-up since I guess that will already come with a ******** ignition timing?
I appreciate that it would be easier to go to AEM, MoTeC etc but, for the time being, I'm going to havge to do it this way.
Any help greatly appreciated!
