I was driving my car today in 20 degree weather. All the sudden temperature gauge was heading close to 220. I shut it off imediately, I started it back up again and discovered there is no heat coming out from the vents, Coolant level was empty in the surge tank. Hoses have no pressure. I pulled the dip stick, and found that the oil got mixed with coolant, the milky stuff. Before that my timming chain cover gasket was leaking, did I blow the head gasket??? or is it from the timming chain gasket???? Please help.
