Viper headers
Godsil Performance
Camas, WA USA
The following are headers for your Viper. The prices are with free shipping.
1992-1995
Black Painted Tubular Header & Crossover
Note: Fits Manual Transmission Models Only
Boost performance and drivability in your vehicle with high-quality Edelbrock Tubular Exhaust System headers. In some cases, you'll shave up to a full second off your acceleration time from 0 to 60 mph because the Edelbrock design improves your engine's ability to breathe. Mileage may also improve, as your engine becomes more fuel efficient. Best of all, the Tubular Exhaust System (TES) headers give you all this performance within acceptable emissions levels and without voiding the new vehicle warranties.
TES headers accept all stock emissions equipment, leaving them fully operational and most systems are complete from the heads to the catalytic converter. The outstanding features built into every Edelbrock exhaust delivers the best in quality and performance. The system include Headers and Crossover for a complete system and maximum Seat-of-the-Pants performance.
Ultimate Quality & Performance
Direct Fit Trouble-Free Installation
Heavy-Duty Laser-Cut or Stamped Flanges
Leak-Free Seal & Superior Fit with No Alterations
Made in the USA
HP & Torque: 15-20 HP/25 ft lbs Torque
Installation: Direct replacement of the stock exhaust manifolds, header bolts up to the existing stock Y-Pipe/Crossover pipe. Requires cutting and welding for installation. Takes between 3 And 6 hours depending on application. All hardware, gaskets, and instructions included.
Tech Notes: Designed for vehicles without pre-catalytic converter. 50 States Smog Legal
TPC Part Number: EDL6606
Retail Price: $2358.65
Jobber Price: $1966.99
Your Viper Club Price:$1645.99
1996-2002
Stainless Steel 1 1/2inch Slip-Fit Racing Headers
Note: Fits GTS Model Only
Borla produces a premium T-304 aircraft grade stainless steel header system to replace restrictive factory cast-iron exhaust manifolds. Turning the front half of your exhaust system into a high-flowing power producer. These Headers are intended for off-road use only.
Thick 3/8 inch Header Flange!
Comes With Stage 8 Locking Header Bolts, Gaskets, And All Other Necessary Hardware!
Includes Any And All Required Emissions Fittings!
Extra High Quality T304 Stainless Steel!
One Million Mile Warranty!
HP & Torque: 20 HP/ 25 ft lbs Torque
Installation: Replaces the factory cast iron exhaust manifolds. Headers are made to bolt on without any welding or cutting. (unless otherwise specified in Tech Notes) Installation times range from 3 to 5 hours depending on experience and available resources. All necessary gaskets and hardware are included.
Tech Notes: Intended for off-road use only. Not Smog Legal
TPC Part Number: BOR17112
Retail Price: $1720.03
Jobber Price: $1462.99
Your Viper Club Price:$1300.00
1996-2002
Stainless Steel 1 5/8inch Slip-Fit Racing Headers
TPC Part Number: BOR17113
Retail Price: $1601.03
Jobber Price: $1361.99
Your Viper Club Price:$1180.99
J DAWG
MS
why does it say for GTS only for the 1 5/8 96-02 models????
J DAWG
MS
I only cut and pasted the info from my suppliers website. I can check to see if those style will fit your RT/10 if you want.
That would be great, but I just noticed they were 1 5/8. Can you get any 1 3/4???
G
Godsil Performance
Camas, WA USA
The reason why they said it only fit the GTS is because that was the only model so far that they had tried them on. But the guy at Borla checked and he said that they will fit and they only have a 1 1/2" or 1 5/8". If you would like to order these let me know. Thanks.
BarryLB
