Vipers back in Grand AM for 2004 !!!!
pdmracing
Atlanta Ga
Not the comp coupe but what the hey! lets race
Other Sanctioned
Series:
2004 SGS Class Rules
Word Version
PDF Version
The 2004 Rolex SGS Class
As of 10/15/2003
SECTION 1 - APPROVED MODELS
1-1 Approved Models
1-2 Eligible Models
SECTION 2 - DETAILED SPECIFICATIONS
2-1 Chevrolet Corvette C5 Z06 (5.7) 1999-2002
2-2 Chevrolet Corvette Z06 (5.7) 2003
2-3 Dodge Viper ACR (8.0) 1995-2001
2-4 Ferrari 360 Challenge
2-5 Porsche GT3 Cup (3.6) 2000-2002
2-6 Porsche GT3 Cup (3.6) 2003
2-7 Saleen Mustang SR (5.8) 2000-2001
2-8 Steeda Q400R Mustang (4.6) 2002
SECTION 3 - CAR PREPARATION
3-1 Car Preparation
SECTION 4 - TIRES
4-1 Official Tire
SGS REGULATIONS
General Class Explanation and Purpose
Super Grand Sport (SGS) is based directly on the 2003 GS I Street Stock Category automobile regulations designed to encourage the development of competition vehicles built from series produced production vehicles.
SGS will compete as a separate class in the 2004 Rolex Sports Car Series with separate driver and manufacturer championships.
1-1 Approved Models - Grand American has developed these specifications for competition automobiles that will participate in the category titled "SGS". Cars must have been in production for road use/or meet homologation criteria, and have been/or be for sale to the public in a regular dealer offering. A Manufacturer or Tuner must present their automobile before being approved.
1-2 The following cars are recognized as eligible models
1-2.1 Chevrolet Corvette C5 Z06 (5.7) 1999-2002
1-2.2 Chevrolet Corvette Z06 (5.7) 2003
1-2.3 Dodge Viper ACR (8.0) 1995-2001
1-2.4 Ferrari 360 Challenge (3.6) 2000-2002
1-2.5 Porsche GT3 Cup (3.6)
1-2.6 Saleen Mustang SR (5.8) 2000-2001
1-2.7 Steeda Q400R Mustang (4.6) 2002
2-1.1 Final Drive - 3.73:1
2-1.2 Fuel Capacity - 25.0
2-1.3 Minimum Weight - 2925
2-1.4 RPM Limit - 6500
2-1.5 Tire size: 285/30/18 front, 335/30/18 rear, 285/30/18 front wet, 305/30/18 rear wet.
2-1.6 Camshaft kit #12480110.
2-1.7 Injector #245008208.
2-1.8 Rear upper control arm P&M # C5W-1F-300 w/plastic bushings.
2-1.9 Two-stage external oil scavenge pump allowed.
2-1.10 Aftermarket crank damper allowed.
2-1.11 GM Performance T2 body kit approved.
2-1.12 Plastic rear window allowed.
2-1.13 Up to two-inch rear gurney lip is allowed.
2-1.14 Grand American Spec Crawford rear wing (reference CAR BODY REQUIREMENTS section of the GT regulations) is allowed installed on the rear deck no higher then the roofline and cannot extend beyond the rear bodywork.
2-1.15 Air Jacks are permitted
2-2.1 Final Drive - 3.73:1
2-2.2 Fuel Capacity - 25.0
2-2.3 Minimum Weight - 2700
2-2.4 Tire size: 285/30/18 front, 335/30 /18 rear, 305/30 /18 rear wet.
2-2.5 Two-stage external oil scavenge pump allowed.
2-2.6 Headers allowed.
2-2.7 Lightweight clutch allowed.
2-2.8 Lightweight doors, hood, roof, deck allowed.
2-2.9 Grand American Spec Crawford rear wing (reference CAR BODY REQUIREMENTS section of the GT regulations) is allowed installed on the rear deck no higher then the roofline and cannot extend beyond the rear bodywork.
2-2.10 Air Jacks are permitted
2-3.1 Final Drive - 3.07:1
2-3.2 Fuel Capacity - 25.0
2-3.3 Minimum Weight - 3000
2-3.4 Tire size: 305/30/18 front, 335/30/18 rear, 305/30/18 front wet, 305/30/18 rear wet.
2-3.5 Inlet air restrictors 2 required at 55mm.
2-3.6 Upper control arms and rear toe link mounts are allowed to be reinforced.
2-3.7 Air Jacks are permitted
2-4 Ferrari 360 Challenge (3.6) 2000-2002
2-4.1 Final Drive - TBD
2-4.2 Fuel Capacity - 25.0
2-4.3 Minimum Weight - 2700
2-4.4 Tire Size: 245/40/18 front, 305/30/18 rear wet and dry
2-4.5 Engine and ECU must remain per Ferrari Challenge specification.
2-4.6 Grand American Spec Crawford rear wing (reference CAR BODY REQUIREMENTS section of the GT regulations) is allowed installed on the rear deck no higher then the roofline and cannot extend beyond the rear bodywork.
2-4.7 Air jacks are permitted.
2-5.1 Final Drive - 4.00:1
2-5.2 Fuel Capacity - 25.0
2-5.3 Minimum Weight - 2600
2-5.4 Exempt from minimum production rule.
2-5.5 Tire size: 245/40/18 front, 305/30/18 rear wet and dry.
2-5.6 Engine and ECU must be sealed by Porsche Motorsports NA.
2-5.7 Must replace OEM centerlock wheel hubs with 5-stud hubs.
2-5.8 The rear upper and lower tow links may be changed to spherical ends.
2-5.9 Brakes - Allowed brake pad/rotor maximum stack height: TBD. Allowed two-piece four-piston caliper: TBD.
2-5.10 Standard Porsche GT3 rear wing is allowed.
2-5.11 Air Jacks are permitted
2-6.1 Final Drive - 4.00:1
2-6.2 Fuel Capacity - 25.0
2-6.3 Minimum Weight - 2700
2-6.4 Exempt from minimum production rule.
2-6.5 Engine and ECU must be sealed by Porsche Motorsports NA.
2-6.6 Must replace OEM centerlock wheel hubs with 5-stud hubs.
2-6.7 Tire size: 245/40/18 front, 305/30/18 rear wet and dry.
2-6.8 Standard Porsche GT3 rear wing is allowed.
2-6.9 The rear upper and lower tow links may be changed to spherical ends.
2-6.10 Brakes - Allowed brake pad/rotor maximum stack height: TBD. Allowed two-piece four-piston caliper: TBD.
2-6.11 Air Jacks are permitted
2-6.12 2002 model year 4th, 5th and 6th gear ratios may be used at Daytona International Speedway.
2-7.1 Final Drive - 3.73:1
2-7.2 Fuel Capacity - 25.0
2-7.3 Minimum Weight - 2925
2-7.4 Exempt from minimum production rule.
2-7.5 Tire size: 285/30/18 front, 335/30/18 rear, 275/35/18 front wet, 305/30/18 rear wet.
2-7.6 Air Jacks are permitted
2-8.1 Final Drive - 3.73:1
2-8.2 Fuel Capacity - 25.0
2-8.3 Minimum Weight - 2800
2-8.4 Exempt from minimum production rule.
2-8.5 Tire size: 285/30/18 front, 335/30/18 rear.
2-8.6 Boost 16 psi.
2-8.7 Air Jacks are permitted
3-1 Car preparation is per the 2004 Grand Am Cup regulations along with the specific modifications allowed in Section 2 above.
SECTION 4 - TIRES
4-1 Official Tire - The official tire brand for the 2004 Rolex SGS class is Hoosier. The spec tire for SGS is the Hoosier "SGS" radial slick. No other tire may be used. Contact: Hoosier Racing Tire (574) 784-3152.
P
pdmracing
Atlanta Ga
like I said before, can you buy a comp coupe & drive it out of your dealer showroom? is it street legal? You can drive a Zo6 & GT3 porsche on the street. It is a street car class.
P
pdmracing
Atlanta Ga
at least we are back, they had a 6 liter limit the past year & they were supposedly not going to raise it. This class is in with the rolex series so it will mean dodge back @ the 24 hour!
Bugeater
Virginia Beach
Why the air restrictors? Do they want the Viper participation to equal that of T1? Will be interesting to see how many people try to field a car...
P
pdmracing
Atlanta Ga
Well they pay 2500 show money for last place in the rolex series.. that pays the entry fees & gas $$. If you do the entire 14 race season, you get 30 or 40k for the next year. My class is 2 below this & we get 30 k for perfect attendance in 04.( and finish in the top 15 in class in points.) Also with endurance racing there is multiple drivers & a chance to rent the other seats. Our neon runs in cup class with 3 hour races max. The rolex is around 3 hours, but many are more, the 6 hour @ the glen, 24 hour @ daytona & many more. This gives the car owner an opertunity to get 2 or more other drivers in the car & help ofset the costs. grand am is NOT like world challange, they frown on rubbing.
mjguflaw
Miami, FL
The real question is whether it has been penalized out of being competitive. It has the highest minimum weight of the cars listed plus the air restrictors, MUCH heavier notably than the Porsches
/Thanks for racing in Grand Am...brought to you by the fair and balanced leadership of Porsche USA :rolleyes:
//Lame
Bugeater
Virginia Beach
I guess that was my point. (Mike's observation) You saw ZERO Vipers run in SCCA T1 nationals this year, and you see very few because of the restrictions. I dont think some guys want to race for the attendance trophy, or last place money.
It just ***** cuz my gut feeling is you wont see alot of Vipers for these reasons.
P
pdmracing
Atlanta Ga
I beg to differ, the cars will be VERY competitive. This is endurance racing, not scca national sprints( which maybee have 2 or 3 cars in class in non runoff races) The viper curb weight is what 3500 lbs, so 3000 is not too bad to start. A GT3 porsche weighs in @ 2860 from the factory & gets less than 200 lbs weight reduction. & the ZO6 has had a great battle with the gt3 in the current GS1 catagory. Moving these cars up to rolex w longer races will even the chances for dodge because of the superior reliability compared to the corvette. They also have larger tires than world challange too. Considering the endurance sucsess of the viper , it is a shoe in for some podium finishes.
Maybee if they made a comp srt10 version of the CC it would be even better. But as it stands it is a big deal & gives all those guys who know have CC's a place to race their old cars.
Dont be so negative, the Zo6 guys are running crate engines & kicking a$$ when they stay together. The Viper will still make some serious HP even with the restrictors. Dont base your thinking on the T1 Results alone.
Remember Grand Am is now run by NASCAR management & they want AMERICAN CARS. The attitude & help they have given us on the SRT4 project is amazing. They want us to be up front. For example, @ VIR this month, they made sure we had the best paddock spot in the place knowing that PVO guys were coming to help. They usually park us by points, which means we would be in the woods! trust me this is going to be awesome, rmember , you have to finish to win & we all know the vipers can last.
ruckdr
Renton, WA USA
Generally, where are the races located; i.e. schedule ?
Any in the Pacific Northwest - Portland, Seattle ??
Later,
P
pdmracing
Atlanta Ga
Later,
The 2004 shed isnt out yet, but 03 was all over, daytona, pheonix, fontana, watkins glen, barber, mosport, mid ohio,Mnt tremblant,VIR,miami
LUDIO
