PBJ
Hey Guys,
I had a little problem with my car the other night while horsing around. I had a T&D rocker break in half on the exhaust side of # 8. This resulted in the pushrod dropping into the block and hitting the connecting rod which pushed it into the bottom of the piston. It looks like a grenade went of in the inside of my motor. Everything is repairable with no major problems... thank god for having spare parts with the help of my friends. Anyway, my reason for posting is, I called T&D about the problem. When I talked the tech he knew exactly what happened before I told him....he said that their aluminum rockers are only designed to last a season or two before failure on nitrous. He said the additional heat and cylinder pressure causes them to stretch and break in half on the exhaust side. He said you can send in your rockers and they will check them for free....maybe we should all send them in this winter while the cars are sleeping. I would hate to see this happen to anyone else. I have been using T&D rockers for a long time and I have never had a problem, but I guess there is always a first time. To give you a idea or time frame on how long mine lasted, I have been spraying my car for over a year and have used at least 60-70 bottles of nitrous. The nitrous has broken every other piece on the car...transmissions, rear ends, half shafts...etc. This is the first engine related problem I have had. So just beware guys.
Later,
Joe
Later,
Joe
