Steve 00RT/10
1) Does anyone have before and after dyno results of a 5lb pulley?
Well.......yes and no. I have a pre SC result on our 2000 car and a post SC result on our 2001 car. Both have 5 pounders.
2000 car: Belanger Headers/3" pipe: 438 HP/480 TQ
Below is the dyno sheet on the 'new' 2001 car. This car was tuned on a dyno in 2003 prior to logging being available. I upgraded the VEC2 late this summer and my suspicions were correct. VERY RICH at WOT. I will finish tuning in the spring. In other words, there's more to get out of this one, although it will likely never see a dyno again to measure it. Getting the AFR right is good enough for me. As an added note, the 2000 car seems to pull a fair amount harder than the 2001 car. AFR in the 2000 is pretty much right at 11.5. I'm still in the high 10s with the 2001 car. It was in the mid 9s to low 10s when I first logged in late September.
How many lbs can you get up to w/o getting involved w/ **** & water?
5 pounds -- cast piston
6.5 pounds-- forged piston
How difficult is the install? How difficult for a noivce?
You can do it. Some mechanical ability and common sense is all that's needed. I am no mechanic, but put it on last spring and tuned it. It's a good experience and you get to learn your car a lot better. You even get a chance to spend a few hours cleaning parts of your car not normally exposed. It's a bonding experience
Steve
