water pump leak help :-(
brukowski85
long island, ny
ok i was told this is a water pump leak ..http://youtu.be/iAF8Dwel6jQ ..thats the link to the video..my questions are if anyone has had this problem does the water pump from rockauto.com work?? is this a do it yourself job??how much would the dealership charge ?
speedracervr4
Lancaster, PA
Geez that's a huge leak, are you sure it's not your upper hose? I would look at getting an OEM pump, it's not that hard of a job to do. I would go ahead and replace the timing chain cover gasket as well.
AZTVR
Chandler AZ
That does not look like a stereotypical water pump failure; but, I do not wrench for a living. I have only seen slow dripping from a failing water pump shaft seal. Nothing so significant as your video. I guess that it could be the gasket for the water pump or timing chain cover. I like the idea that it is the hose; with that amount of fluid coming out. If it is the pump, I wouldn't be comfortable using a rebuilt water pump like what Rock Auto is selling. The engine is just too expensive for me to risk on a rebuilder.
Camfab
SoCal
It isn't hard if your patient and competent. If not, don't do it. The fact that your posting this, tells me your probably in over your head.
xeng yang
