What EXACTLY does...
Danino
it mean when you balance and blueprint your engine? It sounds involved...
pretty much any engine work involves balancing, pistons/rods to the crank etc...
blueprinting i assume is making sure all the parts work perfectly together. but im sure someone with more info will chime in
if its a reputable viper tuner, you have nothing to worry about except your wallet. :)
dave6666
To meet blueprint specification exactly. It is a system of whereas components are checked individually after manufacture, not just assumed to be correct after manufacture. Balancing can be complicated when dynamic balancing is done, but a simpler version is like all the rods and pistons weigh the same as compared to each other.
D
Danino
That's what i figured logically, but thanks, it's nice to actually KNOW instead figure.
1BADGTS
All tolerances are checked (cyl walls,line bore ect ect )rotating assembly parts weighted and balenced .
imflyinbiya
