What tire for 20" rims?
Dawg2Snake
AZ
What tire for 20\" rims?
For those of you that have upgraded to 19" front and 20" rear rims,
what tires are you using and why? Luke, can you tell me what my choices would be?
Thanks in advance!
Luke@tirerack
Re: What tire for 20\" rims?
the only realistic choice would be the Pirelli P-Zero Rosso Asimetrico in the following sizes:
345/25R20
285/30R19
D
Dawg2Snake
AZ
345/25R20
285/30R19
This does seem to be what every one else is using as far as I can tell. I wasn't sure if there was a choice or not, given the sizes. Thanks again for your expertise.
Sam 01 RT10
Las Vegas NV
That's the setup I have, however Tire Rack lists the PS2 in a 335/30/20 for about 100 bucks/tire less, but it is a bit taller in diameter.
jpas
I am running the Pilot Sport 2 335-30-20. They are approx 2.8% larger in diameter then the stock tires. They do have better grip then the P-Zero Rosso's that I tried first.
jpas
Actually what I meant to say is the 335/30/20" is 2.8% larger in circumference.
Phil @ CalChrome
Ive heard from alot of people who come into our shop that the Pilot Sport 2 that jpas mentioned is the way to go as far as grip is concerned. Dont have them on my car, so Im not really one to talk. :p
Viper TT
Delaware
Good luck obtaining the Pirelli 345/25/20 tires! According to what I've been told, they are backordered for at least 120 days. The Pirelli 335/30/20 are about 45 days backordered, which pretty much leaves the Michelin PS2 in 335/30/20.
If I had known of this problem in obtaining the Pirelli tires, I would've gone the 18/19" wheel sizes.
Nader
New York
Pirelli only does limited production runs for these tires so I am not surprised. In fact When I purchased mine I opted to buy one extra rear tire just in case of a flat. that would be a disaster waiting fo the tire.
19/20 is worth the wait...
Luke@tirerack
the 335/30-20 is 28" tall
Viper TT
Delaware
.6" diameter increase over the factory 345/30/19 will have to work considering that no other option is available.
Sam 01 RT10
Las Vegas NV
Viper TT- I got a Pirelli 345/20 in about four days after a nail went through my tread right at the side wall. That was just a few weeks ago. I didn't have time to call/check Tire Rack, but the local Discount took care of it for me.
Viper TT
Delaware
If you get the time, please check to see if they have 2 available. If they do, I'll compensate you for your time. Thanks.
KenH
Portland, OR, USA
Will 335/30/20 be ok on a 20x13? What size would you recommend for up front on a 19x10
Bump - wondering the same thing. Will the PS2 fit a 13" rim or do you need to drop to a 12.5?
