What's the best oil for an RT 10 ???
jbrian31
I just did an oil change on my RT and used Mobil one synthetic 10w30. The hard part was figuring how much oil it was going to take because the owners manual and service manual differed in how much when changing oil with filter. Ended up using 8.5 qts.
99 R/T 10
Enterprise, AL USA
5-30 or 10-30 is an inferior oil when compared to 0-40 "European formula" or the 5-40 Synth. Diesel oil. Best there is would be the diesel Synth. which is what I will be using next time.
Mopar Boy
Ontario and Ohio
I picked up a bunch of 0W40 from Wally World in Buffalo...Cant say I even looked in our Canadian stores! ;)
Diesel, that should be much easier. Go placed where 18 wheelers go. Truck stores, etc. Just dont use Motomaster/Crappy Tire oil. Not so good! ;)
Roy
Netherlands
Maybe I am missing something, but why the ** should anybody put oil designed for a diesel engine in a petrol based car. Or means "diesel" something else as here in the Netherlands?
daytonprowler
Dayton, Ohio
Whyyyyyy? :eater:
Why use that filter on my Prowler? It makes it go faster.:rolaugh: You might want to try one on that yellow Viper of yours!:omg: It will help you keep up with the red ones. :D
Seriously, I've been using that filter since it was introduced to us, I think, at VOI 9.
Be good.
Bill Pemberton Woodhouse
Blair,Nebraska,USA
Get the Viper filter , and yes it will run you about $3 bucks more, but simply put just think ;
1. better flow rate
2. Drain back valve designed for the Viper
3. Built and designed for the stress of a high performance V10 and it's characteristics under load.
4. Better filtering --- tighter particulates if I remember correctly.
The easy answer is racing improves the breed and the filter for the Gen I, II, and IIIs come from that experience and what Engineers found. There is another filter for the Gen IVs.
Enjoy your RT!
BarryLB
