Which spark plugs for NITROUS setup?
trainville
Oregon
I recognize the need for a 1 or 2 step colder plug. I'm about ready to install a wet 200 shot (NX)and was wondering what plugs you guys are using? Any other mods I might need to make?
I'm already set up with the Vec 2 to control WOT and RPM window. Thanks,
Jack B
NE Ohio
The RC10's are two steps colder, the RC12's are the stock SRT10 plug. The RC10's still have the extended strap. It would be nice to find a plug that is colder and has a strap somewhere between a standard reach and and extended reach.
Our cars don't like the standard reach due to the combustion chamber design, the plug is already shrouded. When you go to a standard reach, low and mid range response suffers. The NGK FR5-1 is a plug that is the same heat range as the oem plug, but, it has the strap is half-way between extended and normal. The FR5-1 in one range colder might be a good plug.
