who has the same problem in GTS
m_m2010
who has the same problem I changed shocks and suspensions then new the back became lower than before and how I can fix that?:(
this photo for my viper
JonB
Legacy\Supporting Vendor
Columbia River Gorge
Of course it all depends on the "new suspension" you purchased.
Adjustable? Correct spring lengths?
What kind of tech-support are you getting?
That nose-high attitude is not safe at 100mph +
M
m_m2010
JohnnyViper
Massachusetts
me and JonB have had our differences but he is completely right in his statement "That nose-high attitude is not safe at 100mph +" its plain dangerous!! from my research he has the best price on adjustable shocks, they will dial in your height just right
Dan Cragin
LA, CA
Do you have the correct springs in the front and back, not swapped. They do make spring caps to raise the car, but something does not seem right.
i didnt read this correctly. i thought he only installed the fronts.
as always, dan brings up a good point
JonB
Alignment wont help the ride-height rake. If his answers can be taken literally, I bet he put the Eibach Rear springs in the Front. Where are you MM2010? No offense, please, but I think we may have an English as a 2nd language issue here? I only have one!
Im not clear on what you bought, or did, and what the vendor says about your "dangerous" issue.....
M
m_m2010
I didn't have that but I want try the adjustable suspension
and i will chick if the Problem gone.
M
m_m2010
I am soory jon for dealy,actually, I am realy confused and I think when I try confused then solve the problem!!!!:dunno:
M
m_m2010
Thanks, I will buy it by jon
'Trust'
Is it possible that you have front springs for a Gen I car? Springs designed for steel frame/heavier cooling system front end would raise the front on the aluminum/lighter cooling system gen II's.
M
m_m2010
I wiil chick in this week and I hope to solve the problem
thanks mate:drive:
xeng yang
