Yes I'm afraid so, Just take your time and make note of all the screws you remove Once you have removed the regulator it helps if you hold it in a Vice when replacing the shuttle Slip the wires off the wheels at the end of the track
I think you will find they are both the same once you put the shuttle onto the track you should be able to work out the cable positions If the cables cross each other you will know its not right!
You should be able to piece your old shuttle back together to check?
