Work in progress - Nitrous and Green things
TheOldViperMan
Galveston
Here is the latest on my Go'n Green project. The dual nitrous project will consist of Direct Nitrous by Nitrous Outlet, and conventional intake nitrous by Phastec of Houston.
T
TheOldViperMan
Galveston
More on the 2009 Green Thing from Jason @ Phastek Houston.
im curious to see how the nitrous works, dont know if there have been any gen4's that worked with it. looks great BTW
T
TheOldViperMan
Galveston
Have you actually sprayed it yet, or still working on the details?
Haven't sprayed yet. After both nitrous systems are installed, we will dyno and and compare stage one normal nitrous at throttle bodes to the direct port system we just got back from Nitrous Outlet.
T
TheOldViperMan
Galveston
I'm told Nitrous Outlet has not done a Gen IV before. They did one system that did not have the typical lines going to the nozzles, but plumbed one with lines for me. They still have what I called the "hidden, or secret nitrous set up. They actually installed two rails directly to the nozzles.
see photos.
T
TheOldViperMan
Galveston
Where did you get the smal viper logo I wanted to do the same thing
Phastek in Houston did the Viper logo, and are doing both of the nitrous systems, plus Green LED lighting including gauges, bottle lighting
and engine compartment/interior. They also installed headers and exhaust.
T
TheOldViperMan
Galveston
Any answers to these questions
The Direct Port system is only 125, because the engine is stock. I don't intend to do the cam & pistons for a heavy Direct Port shot. The other
system will be 150 or 175 or more? We are using a dual controller and may use both staged?
Still mulling things over.
JAY
Ontario Canada
Nice Ride ! Having done Nitrous on a Big Block Dodge in the early 80's , I can tell you your in for a lot of fun , when done right . :2tu:
SRT09
Edmonton
So what are you doing for fuel and timing control?
T
TheOldViperMan
Galveston
Haven't been there yet. Jason has a lot of Viper experience, (at Hennessey & RSI) and has done several successful nitrous and supercharger installs for me in the past.
He will be tuning soon, and I'll post as we go.
BillyC
SRT09
Edmonton
BillyC
Be interested to see how he works around the Gen 4 PCM
T
TheOldViperMan
Galveston
If I remember correctly, early on, Jason mentioned that we would need to purchase a special "PCM" and later told me it had arrived at Phastek.
I will follow up on that interest SRT09, as it concerns me as well. I hate check engine lights.
BillyC
SRT09
Edmonton
BillyC
Plus the only PCM I think that exsists is the Mopar and it non programmable and increases timing which would be bad when spraying!
T
TheOldViperMan
Galveston
The Green Machine is a Show & Go project.
Heavy on the "Show" and light on the "Go".
This project is a father/son bonding thing.
My son, Chris, is a wrench head (tech) at BMW, and if it were up to him the engine would be completely rebuilt for direct port nitrous, max hp & torque.
But the old man ($$) has had many high HP cars and is "slowing down".
Obviously, without forged pistons, cam, p&p intake, etc, the project is going to me much more Show than Go.
I hope SRT09 and Chris never meet up, because they will gang up on me and my show car.
T
TheOldViperMan
Galveston
:DLatest on the Green Thing project.
Stage "1" & Stage "2" nitrous oxide systems about done.
BillyC
Nine Ball
Houston, TX
Nitrous works just fine on a Gen 4. Just need the proper electronic control devices. RPM window switch, WOT switch, etc... Wet kit is the way to go.
Cerevo
