Hey since someones on the topic, I purchased a set of EBC red's a little while back. What's the best way to break them in?
taking care NOT to lslip and possibly lacerate the dust boot.
Fronts are easy to change, Remove front wheel, Using a small drift (blunt Nail) knock the pins out, remove the spring pad, slowly pry the pads apart and remove them. Check the dust seals are in good condition and replace pads![]()
The rear caliper has to be wound inDo not try to force it in with pressure as you will damage it. Also be very careful with the rubber gators on the rear caliper (where the caliper slides back n forth over the disc) they can split really easley if fully compressed.
Here's a link to How to rebuild the caliper http://wiki.seloc.org/a/How_to_Rebuild_a_Brembo_Caliper
It explains how the mechanism works![]()
Your very welcomeThanks for the link and info ---
You do realize that's above the speed limit in most placesWhat I do is 4 runs from 100-5mph, 4 runs 80-5mph and 8 runs 60-5mph.
By using the break in procedure that comes with them.
What I do is 4 runs from 100-5mph, 4 runs 80-5mph and 8 runs 60-5mph. Stomp on them hard but don't come to a complete stop, you will get some "green" fade and your pads will be smoking a little that is normal then drive about 5 miles without touching the brake pedal to cool them down and you have your pads bedded in.
Thanks dave...
But my EBC's did come with instructions. And I did follow them. I do trust the manufacturers![]()
I'll be doing Hawk HPS if I ever wear out those non braking reds. But, meanwhile, my no dust wheels stay so purdy.
I've got 14" SRT brakes. Got the size factor covered. The reds were recommended by the vendor I bought the brake / wheel / tire package from.
This is so easy even I can do it.![]()
I have reds fitted to my stock size Gen 2 front calipers, I get a lot of dust off them when tracking the car? Can't say Im over impressed with them for stopping power! I was going to try the Pagid RS Racing brake pads next, more expensive but Hopefully they might anchor up better?
And Dave 14,770 posts? You *****.
