I checked the service manual, found above which refers to generic scan codes....noting that the "55" code pertains to the flashing MIL code system and does indeed mean "completion" of the fault codes that one can generate on early GenII's by turning key on-off-on-off-on-off-on (to run position, NOT start position) for three cycles within a few seconds, then counting the times that the "check engine" light flashes. For a cross check of the code, a scan tool code of "0505" should show a MIL code of "25". Hope this helps.
In addition to cleaning contacts, might want to carefully clean IAC inlet at air box. Can't really tell you much about IAC motor...but it seems to me that someone posted about fixing its servo once for a 0505 code after wiring proved to be OK. Next step for ME would be Viper Tech.
