Air box bracket
chex
I am reinstalling my factory airbox and I can not find the bracket that mounts the box to the frame. DOes anyone have one they want to part with? thanks
FE 065
MI
Not quite sure of any loose brackets used to hold a Gen2 airbox to the frame. There's two bolts going thru at the front end, and one in the middle at the back.
V10SpeedLuvr
I need the bolt that goes in the middle of the airboxes for a Gen 1 if anyone has a spare. I took mine off and forgot to put it back in before I drove the car. No telling where that thing ended up
PhoenixGTS
Phoenix Arizona
THANK YOU FOR REMINDING ME that I need to make one for my car. Stock one is a no go since I had to move the airbox rearward to fit the thick radiator. I had totally forgotten about not having one.
V10SpeedLuvr
Nevermind. I just popped my hood to check on something and saw the bolt stuck down by the passenger side headers. Thats amazing considering the car has been driving almost 1,000 miles including a trip to FL since I took it off and forgot to reattach it!
C
chex
Thanks, I am looking for the bolt and bracket that is in the middle at the back end. Anyone know where to get one?
FE 065
MI
The rear brackets are not removeable on the Gen2's. Is it the bracket on the aluminum crossbrace that's missing? I think that was welded on.
Shouldn't be hard to fabricate one. Even one that 'bolts on' if it's too hard to get it welded on.
The airbox side pf the back bracket is molded into the airbox's back half.
C
chex
yes it is the one that mounts to the cross brace. I figured I could make one, but if someone had one...
FE 065
MI
I'm guessing the non-OEM airbox install required the removal of the welded on Al bracket and its' clip with the threads on it.
