Check Engine Light
Jeff Lemke
Holly, MI
It's now coming on every so often, and the motor has started to run a bit rough. I wanted to check here first to see if there is a commom cure before I took it in for service.
New plugs and wires about 1500 miles ago. Any help would be great.
Thanks.
Jeff
ArlyDude
PA
Perhaps an o2 sensor. Happened to me. Get it check for free, then buy a reader.
ViperJohn
Maryland
If the light is coming on periodically, I would suggest re-checking the plug wires, maybe one is loose. If you had an 02 sensor fail, it would stay lit all the time.
Go to Advance Auto and you can pull the code for free.
zeeshan_k24
