Clearing check engine codes.
Ulysses
San Diego, CA. USA
Re: Clearin check engine codes.
Why not get an OBDII scanner that's backwards compatible. Then you can use it on your newer vehicles as well.
ACELLR8
Harrisburg, PA
Since it is a 95 you can first check the code by turning the key on and off 3 times. This will give ya the check engine diagnostic code. You simply count the number of flashes in-between the pauses. One of the nice things about the Gen I vipers, not available on the Gen II's.
If you have a service manual you can find out what the codes are in it, or usually a call a local Dodge dealer and ask someone in the service department.
To reset the code, you can unhook the + on the battery behind the rear wheel. Don't bother trying to unhook the remote post upfront as the PCM still keeps the code, or at least this is what I found.
Also if you simply get a 55 that means there are no more codes, that will either be all you get or the last code you get.
B
Bill B
Plantation, Fl. 33323
I thought that disconnecting the power would do it. I didn't realize that you couldn't do it from the remote disconnect.
Thanks.
Ulysses
San Diego, CA. USA
Disconnecting the battery terminal not only clears the code, it resets everything the PCM has learned.
