klamathpro
I have the common GenI leak under the right front Facia where the hidden fill bottle is located. It happened overnight after a run the day before. I know it did not leak when I parked it because I always wipe the Viper down with Meguires Final Inspection after each run and I didn't see or smell anthing. I can't see where it's comming from but opening the wheel-well circular cap revealed a mess of antifreeze. My facia bottle is about empty and it was full the day before (I check before every run.) Main upper fill bottle is full.
Do I need to remove the facia or do I just try burping? If I do need to remove the facia, why does everyone say that the christmas tree push-in clips need to be removed? Can't I just remove the six bolts holding the bumper on the frame and remove the bumper with the facia attached? Everywhere I looked, everyone says to remove the PITA clips but the manual doesn't show them as a removal step. Plus check out this link:
http://forums.viperclub.org/showthread.php?t=593597&highlight=remove+front+facia
He has his attached, can I just do that and skip the clip mess? I hope I don't have to remove it at all.
thanks in advance
thanks in advance
