LifeIsGood
I got my Corsa cat-back installed, but the tips are sitting a little low in the rear fascia opening...
The bottom of the pipes are sitting on the bottom of the rear fascia opening...
I've sent pictures of the installation to Corsa and they said that it was all good, except that the pipes should not be touching the rear fascia opening
The front most part of the rear muffler assembly is attached via the center mounting bracket and the rear most part of it (the rear muffler assembly) is attached via the lateral adjustment bar, neither of which has any vertical adjustments
Has anybody else run into this issue? How did you solve it?
