pokeyl
- Joined
- Dec 11, 2016
- Posts
- 139
- Reaction score
- 58
Anyone having problems starting any time the battery is not fresh from the charger? I have found the voltage drop when starting makes the starter relay chatter!!! Hard to start.
I have changed the Starter and ground cable at the battery. As well as the starter relay, No Difference. One time i ran a set of jumper cabled the add extra amps to the system. Still had relay chatter.
My current solution is a Solid State Relay. It will not chatter as it has no moving parts and will stay energized as low as Five Volts.
First test went well. Will test all summer and see if it is a "Total Fix."
