Heads Investigation???
viperkraz
270 cfm is not enough improvement. Get Greg Good or Jeff M to do it. Both have an awsome product and results!
1TONY1
Dalton Ga. (Chatt. Tn.)
When you have serious problems like the picture shows .... Mr. Good makes it look brand new, couldn't even tell it had damage after he was done. This was on a Viper that had eaten a valve. This is the combustion chamber, one valve missing except for the stem.
GTSnake
Motor City
I have a set of Jeff Mory's stage III heads including T&D roller rockers for sale if you're interested. They only have 3,000 miles on them. I'd let it go for $4,500. No core exchange needed.
ViperRichRT10
Suwanee, GA
Tony,
That looks somewhat familiar! Only not a valve, a piece of piston playing "pong" inside the cylinder!
Rich
Joseph Dell
Atlanta, GA 30338
Looks kinda like this:
Why? because this piston took a dump. note how many pieces the piston is in. You may also notice a piece of the upper ring missing. doh!
Is this bad?
But I think Tony's pic wins the prize. it is worse than my pic. Fortunately, neither of these are our cars!
JD
Jim Wilson
Chandler, AZ, USA
Best used while rods are still bolted to the crank ;)
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=90125
Don't waste your money on these. I bought a set to stamp my rods for my piston swap. When I struck the first one, I flattened the stamp and barely scratch the rod. I've had good luck with a bunch of Harbor Freight stuff but these will only work on softer materials.
caj98GTS
Houston, TX
Go to Greg. He is a true professional and one hell of a craftsman. You will not regret sending your heads to him.
