Don_
Hello all,
I started work on installing Woodhouse motor mounts and ran into a problem (gen 2). There doesn't seem to be enough room to remove the the top lag bolt that holds the mount bracket to the engine block. I have the stock exhaust manifolds and the top bolt hits the collector. Is there a trick that I'm missing? Even the owner's manual says to just remove the bracket (by magic I suppose ha).
I did a search and saw that someone else ran into this problem and they cut the bolt down to be able to get it out. I don't want to resort to this or remove the manifold. I really hope someone can help me out. Thanks!
Don
Don
