HID Headlights
SYNFULL
Bucks Co, Pa
Hi,
I just bought these HID - 80 8000k from rj dist. and can't get them to work. It looks simple enough, the light fits right into where the stock bulb was, and the stock connector plugs right into the ballast. I have tried both bulbs and ballasts with no luck. Can anyone give me a heads up as to what I might be doing wrong.
Also where have you guys mounted the ballasts that have installed these?
Gary
vipeuup
OR
Syn,
here is a pic of a HID diagram. What it should be. I got mine from www.gohid.com . Its just plug and play . Mines the 9005 kit 7000Ks
[image]
[/image]
SYNFULL
Bucks Co, Pa
vipeup
Mine didn't come with the "igniter". maybe it's built into the ballast? I called the place I got it from (RJ Dist) and he told me to reverse the wires going to the bulb. I cut and soldered the red to black and black to red- still doesn't work. I will have to call him again tomorrow.
Thanks!
Gary
vipeuup
OR
Syn,
you ought to just return the ones you bought. And order a new kit from Vince , www.gohid.com . Mine works great, and theres no issues whatsoever.
NOTV8
You need igniter to use a HID ballast. Without it, it will not work.
Cop Magnet
Kenilworth, IL
FYI, I mounted my ballast boxes inside the headlamp housing. Fit perfectly velcro'd to the back inside cover behind the high beam lamp. Nice that way, it's all self-contained.
SYNFULL
Bucks Co, Pa
Cop magnet,
That's exactly what i was thinking of doing.Well I don't see an igniter so I call in the morning. Thanks for all the help
Gary
vipeuup
OR
Cop,
We All mount our HIDs inside the lamp housing. Dont know anyone that doesnt...
SYNFULL
Bucks Co, Pa
Just for the record if anyone else buys these they work great but you have to do some easy alterations.
The wires coming from the connector that went to the old light now go to the ballast. They have to be reversed. The clip comes apart and you reverse the red and black wires and fit the connector back together..
The igniter is built into the ballast.
Gary
GTSnake
Motor City
I hope they change the kit so it's more plug and play and not "modify-plug then play..."
zeeshan_k24
