How to set the "quantity of teeth" for speed sensor in the ABS electronics?
ike
Germany
Hello,
does anybody know how the standard brake software can be set?
With the Bosch KTS 670 computer I can see the number of teeth for the rear-axle differential as the ABS but I can not change it.
The ABS including software is from Dodge RAM SRT-10, which is used in a BMW Z4 now.
The number of teeth is actually set to 120.
The value I need is about 65.
Is there also a function to correct the speedo or is this the same function?
The speedo shows speed about 40% too high according to GPS.
Can you help, or do you know someone how could help me?
Mando9595
