I'm trying to gauge interest on a group buy of B&M shifters for the Gen II
Camfab
SoCal
Ok here's the deal. I've been thinking about changing shifters for a while now. The Hurst shifter seemed like a candidate, however after reading about clearance issues with that shifter and the fact that youv'e got to remove the shifter to pull the trans out has me thinking otherwise. Hurst ,B&M, and Flowmaster are all part of the same group now. I'm guessing due to overlapping product lines they have done a soft cancellation of building the B&M shifter. I spoke with a gentleman at B&M today and told him about the issues with the Hurst shifter, and asked him if I was able to get enough interest for the B&M would they do a short run. So if enough interest can be generated here, they may consider doing a run for us! Who's interested..............
I'm obviously in....
C
Camfab
SoCal
I didn't ask about the price yet, but I'm sure they will work with us.
MTGTS
Orlando, Fl
You don't have to pull the trans to install the Hurst. Just simply unbolt the trans brace and lower the transmission an inch or so. Slide the shifter in, and raise the trans back up.
s55c
If a good deal can be had I would like one as well. Funny that there web site shows an "onsale" price but then its not available,,, good luck motivating them.
C
Camfab
SoCal
Actually I think your misunderstanding me. I'm not talking about installing the shifter, I'm talking about removing the trans. With the stock shifter or the B&M which has copied the OEM shifter, you simply remove the shifter handle and then proceed with the standard trans removal procedure. I personally don't like any aftermarket parts that add a step in future servicing. That's just me.
Viper98912
Atlanta
Anyone have any pix of what the B&M looks and feels like? May possibly be interested. I want to keep the car mostly stock but this is one of those little ones that may be worth it.
SandViper
I'm down!
I don't see from the pics on there site does it have the lock bolt to adjust the in gear setting aswell? I remember using a shifter in the past that had an adjustable screw so once in gear you could back the screw to the shift rod to keep it from over throwing the gear and bending the internal forks, unless I'm dreaming this up??? I can't remember if it was B&M or Hurst but thats the one I want.
AZTVR
Chandler AZ
I'm down!
Neither the Hurst not the B&M that I have owned for the Gen 2 Viper have the feature that you are talking about. The picture on the box for the Hurst shows an adjuster screw like you are talking about; but, it looks like a generic picture, not identical to the Viper shifter.
C
Camfab
SoCal
I believe one particular generation of the B&M shifter did have the adjuster screws. I will inquire on Monday, I've been too busy at work.
99 R/T 10
Enterprise, AL USA
The earlier versions had the adjusters, but since the T-56 trannies have positive stops, B&M dis-continued using them, just not necessarry.
C
Camfab
SoCal
Okay, some details. I appologize for the lack of info. this past week, I've been working crazy hours and have had little time to do anything else. I did have a chance to play phone tag with B&M and did get some info. First the good news...........they said that they would be willing to do a special run for us. The catch being a run of 100 units. I am going to get in touch with them this week and see what I can do as far as the numbers. I see interest is up which is great.
WDW MKR
Alabama
Thanks for looking into this! If they won't/can't lower the numbers enough to make it work for what is likely to be a couple of dozen VCA/VA members, perhaps one or more of the supporting vendors would want to get it on it and have some on their shelves.
C
Camfab
SoCal
I've already contacted one of the vendors, so hopefully it'll all come together.
Viper98912
Atlanta
I thought a special run was going to be like 10-25 units, not 100 worth. It would be nice to see a vendor step up to the plate and possibly order them all to be the exclusive seller.
eucharistos
Houston
good thinking gents
SandViper
How early are we talking? 93-95 or 96-01? I definitely don't feel any positive stops on my 97.
s55c
a lil bump to keep it alive.......... ANY word yet on if this might happen?????
Viper123456
