snampro
I’m working on my cooling system and was going to replace the intake manifold with what I understood to be a more reliable version. My intake has 4 thin silver ridges running down each intake track, the “better” model has 3 large ones. An experienced mechanic and friend suggested the change because my version is prone to failure (the one on my car was replaced not long ago due to a fuel leak. I still have the manifold on my car and the one I am going to replace it with in my garage, but they are dramatically different. I’m posting this for your information and for your input. An overview picture of each manifold is below:
First, in my microfiche shows several versions of the intake manifold:
#5245 651 1992-93, Up To, Serial #104
#5245 637 1993, From, Serial #105 To, Serial #1421
#4763 401 1993-96, After, Serial #1422
The last eight of my VIN are RV101279, so it seems mine should be the bottom one because it is a ’94.
Differences between the manifold on my car and the manifold I was going to install are:
AIS Sensor Location: The manifold on my car has the AIS sensor at the back of the right intake track, the manifold I have that I was going to install has the AIS just behind the right throttle body. This isn’t a big deal to relocate and requires minimum work, just a different pipe that I have and extended sensor wires. Pictures below.
The microfiche lists the following versions of the AIS sensor system hose:
HOSE, AIS Supply
#5245 454 Up To 2-10-94
#4763 539 After 2-10-94
Fuel crossover between the throttle bodies: The one on the car has a removable metal line, the one I was going to install has this crossover integrated into the casting. Again, not a problem, just noting the difference. However, this makes me think my intake is a ’93 because this cross over line is only listed as a part for 92-93 Vipers (since the line is integrated in the casting for later years).
Microfiche says:
#5245 412 TUBE, Fuel Crossover, 1992-93
no listing for such a part after ‘93
Fuel line at the bottom and back of the right side intake track: The one on the car is just below the AIS sensor and uses a plate and gasket with two screws, one on each side of the line. The one I was going to install is in exactly the same place but has the line simply screw into the manifold (pictures below). The line that is on the car runs down from the manifold, under the thermostat cooling crossover, and connects to a fuel line with the standard quick disconnect above the transmission (picture below)
This line is apparently called the rail assembly fuel supply, microfiche says:
RAIL ASSEMBLY, Fuel Supply
#5245 649 1992-93
#5245 792 1994-96
Fuel pressure relief: The one on my car has this at the rear of the left intake track. The one I was going to install has this at the top of the right track.
So, it appears that I have a ’93 intake on my ’94 and the on I have to install is a 94-96 intake. It also appears that I will have a better chance of replacing the manifold should it break if I go ahead and convert the car to the newer intake version. I think now all I need to do is order the new fuel supply line and I’ll be set since I already have what I need to move the AIS system and the fuel crossover takes care of itself.
Your thoughts/advice/comments? Just trying to gather your collective knowledge and what I’m learning about these unnecessarily complex vehicles…man I love VIPERS!!!
Thanks,
Ben
HOSE, AIS Supply
Microfiche says:
#5245 649 1992-93
#5245 792 1994-96
Thanks,
Ben
