lightened flywheel
Nadine UK GTS
Bath, Somerset, UK
If fitting a lighter-weight aluminum flywheel...
1) Does the crank need re-balancing?
2) Would the lower center weight cause less momentum, and lose a few mph top end?
Marv S
Scottsdale, AZ
don't need to rebalance the crank, but good to balance the flywheel and pressure plate and then balance them as a unit.
The Heavier the flywheel the more energy it takes to turn. The heavier a flywheel the more it will resist change in speed, either faster or slower, than a lighter one.
more info at:
http://vca1.viperclub.org/ubb/Forum14/HTML/000750.html
<FONT COLOR="#ff0000" SIZE="1" FACE="Verdana, Arial">This message has been edited by Marv S on 12-08-2001 at 04:14 PM</font>
N
Nadine UK GTS
Bath, Somerset, UK
Thanks Marv,
Although it will rev freer, once actually spinning and say at max sustained RPM, would the momentum of a heavier one give that little bit more in MPH? (Like a greater centrifugal force and aid spinning??)
apexSRT
