More thoughts on that flywheel.
If you have a car that will light the tires in low at full throttle while TRYING NOT to lay tire - it may be a real clever tuning trick to size the flywheel so that you just avoid wheelspin given a particular tire/surface/HP/gearing condition.
Of course, the wider the transmission ratio, the better this would work because in 3rd or 4th gear, you really would like no flywheel mass since there usually is not a wheelspin problem.
Another concern might be if you had 600 to 800 HP. Here you may wish to size the flywheel so you do not get wheelspin at, say, 100 mph in your lowest, appropriate gear. Forget about taming 1st or 2nd.
This, actually is quite interesting because it appears to be different from the traditional applications where HP is limited: The drag racer looking for a heavy flywheel to launch car with monster slicks/suspension and the circle track racer who wants no flywheel to max accel out of the corners.
It figures - the snake was always looked down upon by humans - hell, most people don't even want to eat snake!
Tom
