Need Engine Blueprint Specs
Johann
Sacramento, CA
Anybody have blueprint specs for the GEN II motor or a source for such info?
Need:
Crank centerline-to-block deck dimension
Connecting rod center-to-center distance
Piston compression height
Deck height
Head volume
viperkraz
Try looking in the service manual for your engine. I dont have the manuals myself, so I can't help you.
Schulmann
Canada
Those who know all this information and blue print engins likely don't how to use a computer ....
And those who use this forum have no idea about blue printing but know everything about computers ...
Computers and blue printing are two very different sciences.
WICKDXS
Vancouver, WA
Check out this site, http://www.portpros.com/ViperGenIII.html It deals with a GenIII but they may be able to point you in the right direction, if you need the specs from the service manual pm me & I'll scan a copy of the 2001 numbers for you, but Blue printing does not just mean returning to factory tolerances it involves much much more, including balancing, machining and assembly to very tight tolerance. There should be commercially available "Hot Roding" sources for the V-10 a Google search might return some resources.
J
Johann
Sacramento, CA
Unfortunately, the FSM has none of the specs I need and the Gen III is different.
I don't really intend to do any blueprinting, just curious as to the numbers.
naimsito
