OBD computer codes
zorroespanol
VCA Member - New England
Miami Beach, Fla. U.S.A.
Hey guys....
Anyone know if it is possible to make the OBD codes pop out on the Odometer or Radio??
I have a check engine light on, that I suspect it is from the O2 sims... but before I lift the car I'd like to read the code.
Any input is greatly appreciated! thanks!
NoRice
Chatsworth CA
I know they show up on the odometer as mine did this weekend, but I didn't make it do it. :) So there must be a way to do it.
Z
zorroespanol
Cycle the ignition 3 times and the codes will show in the odometer.
That's what I heard, and I've tried it with no luck!!! No idea why not....
Ive cycled off-on-off-on-off-on and acc-on-acc-on-acc-on.
Any idea whether the codes should show on ACC or ON??
thanks!
Z
zorroespanol
Thanks guys, but I figured it out. I had to cycle on-acc-on-acc-on SLOWER than what I was doing.
I had high voltage on one O2 sensor, but the check engine just went away... so the problem fixed itself (?)
zeeshan_k24
