Padded Lug Nut Sockets
Stealth
SoCal
Does anyone have any good suggestions for a padded Lug Nut Socket to avoid damaging both the wheel and the lug nut?
I know about painter's tape around the socket and working on the skill of the nut behind the socket!
Thanks for your input.
wes
League City
I take good care of my wheels and never needed a padded lug nut socket...didn't even know they made them. Maybe Snap-on or Sears?
Stealth
SoCal
Funny you mentioned Harbor Freight. I called them and they said that they do not carry anything like that! I didn't check for plastic sleeves.
I know Gorilla Automotive makes "thin wall" protective lug sockets.
steve911
Cottage Grove, Wi.
I have an older Harbor freight double ended lug nut socket set. It has the plastic sleeves. It has been replaced with the set that I have a link to below. The are single ended but have the plastic sleeves.
[media]http://www.harborfreight.com/media/catalog/product/cache/1/image/9df78eab33525d08d6e5fb8d27136e95/i/m/image_2955.jpg[/media]
Hope this helps.
dave6666
Switch to McGard spline drive. 1/2 pound lighter than stock.
__________________________________________________
Please note the complaint-free content. Dave, contemporary mod-rice Viper/Ricer owner, and I approve this message.
JohnnyViper
Massachusetts
your suspension is very clean....i have another weekend project. :D
jerseydave
Summit racing sells them with plastic sleeves. If you can't find them let me know and I'll dig out the part number.
Dom426h
DE
LMAO at the title of this thread. ....and the 1st post; Protect yo nutz:rolaugh:
I wasted my money on a plastic/nylon sleeved sockets when on a shopping spree at harbor frieght. They dont even fit in the small bore holes on my HRE's. Nor do most impact sockets. so I have been using a standard sears crafstman socket. Been holding up fine with my cordless impact gun.
AZVIPER
Tucson, Az.
The socket you need is a Porsche item. The Viper lug nuts are 19mm or a sloppy 3/4. The lug nut bore hole on the std Viper rim is 32mm. Google "porsche lug nut socket". If you look at the lug nut on PCARS.COM you will see the socket I'm referring to. It is a 19mm lug nut size in a 24mm socket & 32mm total width. It works great on the std rims. BUT, I now have Iforged rims that have a 30mm lug nut bore so now it doesn't fit. I looked at some of the other sites (automotion.com) & they look like they might have a smaller width socket.
Sinusbeats
